rear ends
Guest
Posts: n/a
rear ends
I want to put a 10 bolt disc brake rear end in my 86z(has 4.10),but want to keep rear drums(I do have all of the parts for disk). Do drum backing plates match up to disc rear end? I am not sure if axles are same length.
84zgt4
86z,87
92rs
95z
84zgt4
86z,87
92rs
95z
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
no. disk and drum backing plates are different. They don't even use the same bolt pattern attaching to the housing. Axles will be the same.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
