Installing new 700r4
Old Nov 15, 2001 | 11:02 PM
ChevypickupTPI's Avatar
Any things i need to be cautioned about, Easier ways you all know how to do it. ANd then how do i adjust the tv cable. B/C i heard that if they arent adjusted right that you can burn the tranny up real quik like.
Old Nov 16, 2001 | 04:06 AM
transfixleo's Avatar
Make absolutely sure that the converter at all times spins freely while you are bolting the tranny to the engine.
To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
camaro11j
Sep 19, 2018 08:49 AM
formula_novice
Aug 18, 2015 08:48 PM
TreDeClaw
Aug 14, 2015 06:58 PM
fonzie85
Aug 13, 2015 11:50 AM
drathaar907
Aug 6, 2015 04:20 PM
