question about tranny and gears
Old Nov 16, 2001 | 10:58 AM
82sportcoupe's Avatar
i have an 82 camaro sport coupe. It was a 4 cylinder at one point(gasp) and had a 4speed manual tranny with 3.42 gears. I swapped that setup for a 305 and a 700r4, i left the 3.42 gears in it. Now i am putting a 350 in and a 400 turbo tranny. I think I might change the cam and intake on the 350 and that will be it. Question: do you think 4.10 (4.11, whatever) gears would tear me through the powerband too quick? should i maybe consider 3.73's or should i just stick to the 3.42's? i will mostly be using the car for the street, not even the highway really. i want LOTS of low end torque. My brother says i should go with the 4.1x's. but i am not so sure.
Old Nov 16, 2001 | 11:08 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
How do you like your mileage now, with your th700? It will be worse by getting rid of the overdrive, but maybe not noticeable around town. You'll get better 60ft's if you put in 3.73's, as long as you can get traction. The th400's have a higher first gear then yours, but I wouldn't say a bigger gear then 3.73 is practical for a street car, because I believe you can only calibrate the th700 for up to 3.73, I don't know about the th400's. good luck- Randy
Old Nov 16, 2001 | 12:02 PM
gas mileage is not an issue. i wont be using the car as my daily driver. i will just use it to cruise around town on those nice summer days. i figured that the 3.73's would be my best choice. my brother is crazy cuz he was trying to get me to get 4.56 gears. i shot that idea out of the sky though cuz i want a cruising speed that's higher than 55mph. haha
Old Nov 16, 2001 | 01:32 PM
Tom84L69's Avatar
Car: 84 Z28
Engine: L69: cam and porting
Transmission: T5, 3.73 rear
I would get the 4.10, especially if you don't go on the freeway. They will feel very nice. My friend has a 4.10 behind a 355 with a Th350 trans and it launches nicley.
84 Z28 L69. 5 speed with 3.73 posi (broken)Ported heads, intake, 10:1 comp. 230/230 .480 lift cam @.050" w/108 LSA
Triumph Spitfire SCCA roadracer. 1.1 liter 4cyl w/ 14:1 comp.
Outcorners anything!
Old Nov 16, 2001 | 02:22 PM
well, its hard to say. i like the 3.73 idea, but i think i might go with the 4.10's. just because i want to be able to CRUSH these friggin mustangs out here. there are so many of them, if only they knew what beast is coming out of the darkness.... thanks guys
camaro11j
Sep 19, 2018 08:49 AM
crazynights
Aug 21, 2015 06:53 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
hokis
Aug 9, 2015 03:57 PM
