eBay 4th gear lock-up kit??
Old Aug 6, 2009 | 05:29 PM
88TransAmFreak's Avatar
Car: 1971 Camaro
I bought this off eBay to control the 4th gear lock-up for my carb set-up with700r4 and I just want to understand how this works.
No instructions, the seller just sent this picture and said to attach the wire to a 12 volt keyed source
Anyone that might be familiar with what this white thingy actually does when I attach it to a keyed source and the positive on the solenoid?
Is it just a pass through? It has a rubber grommet on it so I'm assuming it goes somewhere where it would seal against something.
I don't like hooking stuff up w/o knowing it's actual function, I know some lock-up kits work off a vacuum switch, not the case here.
Old Aug 7, 2009 | 07:11 PM
liteumup387's Avatar
Car: 1982
Transmission: 350
Re: eBay 4th gear lock-up kit??
hey man i was lookn around on the internet and i came across this i donno if its what your lookn for or if it will help you but i think it might be useful
heres the website just scroll down he starts talkn about the tcc and gives a few Schematics
http://www.montecarloss.com/SSThunder/drivetrain.html
Old Aug 14, 2009 | 11:35 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
There's a sticky in the carb board regarding lockup on the 700r4, lots of good info:
https://www.thirdgen.org/forums/carb...c-control.html
I will probably doing this kit myself in the near future since it is relatively inexpesive and will do what I need while I'm saving for the genIV swap
Old Aug 15, 2009 | 08:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's different than mine, but I believe what happes is that the white piece goes in the friver side of tranny where the stock 4 prong connector is. The the wire goes to a switch (not a keyed source - as it looks like if it were a direct connection, your TC would be locked whenever the car is turned on). When you turn on the switch, the power is sent to the 4th gear solenoid to make it it lock up.
Mine is backwards I think - as my switch connects the ground for the circuit, since my vacuum switch also makes a ground connection when the vacuum reaches right level. (sounds like YOUR switch will connect the power side for the circuit).
But - I'm guessing here!
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
dhonda200
Aug 11, 2015 11:50 PM
