Can someone explain me how to properly install drive and driven gear ?
Old Aug 9, 2009 | 11:33 AM
GhostRider_fr's Avatar
Hi there !
I've just rebuilt my rear axle, swapping from a factory 2.77:1 gear ration to a 3.23.
So I chose new drive and driven gears for having a correct speed indicated on my speedometer.
However, when I installed the drive gear, it was such a tight fit on the output shaft that I believe I didn't installed it in the correct position.
The driven gear seemed to contact the drive gear only on something like 2/3 of it surface area.
So, could someone explain me how to install properly the drive gear on the output shaft, and how to install properly its retaining clip, 'cause I guess I haven't understood the procedure very well.
Thanks in advance for all the help you'll bring to me !
Pierre
Dinard - France
Old Aug 9, 2009 | 11:37 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: Can someone explain me how to properly install drive and driven gear ?
I never tackled such a project, but I'm sure someone can chime in here.
Old Aug 9, 2009 | 12:11 PM
Krik's Avatar
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
Then why post if you have NOTHING to contribute?
Old Aug 9, 2009 | 01:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by GhostRider_fr
could someone explain me how to install properly the drive gear on the output shaft, and how to install properly its retaining clip...
I'm unsure of what trans you have, but here's a link to a T5 sticky. Check post #1 of the following link (there are two links therein that should provide some assistance):
https://www.thirdgen.org/forums/tran...ve-driven.html
JamesC
Old Aug 9, 2009 | 01:37 PM
Oh yeah, sorry, I forgot to mention that it is for a TH-700R4
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
hectre13
Aug 26, 2015 08:17 AM
