Sensor locations on T56???
Old Nov 18, 2001 | 10:41 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
Can someone tell me what each of the four sensors on the T56 are for?
Also, it would help if you could tell me the location of the sensors.
I have a T56 sitting in my garage and I see 3 plugs on one side and 1 on the other.
Thanks,
Tom Milmont
'89 Formula 350
13.2sec@101mph
My Page
Old Nov 21, 2001 | 12:39 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Going off memory here, the one on the driver's side in the back under the shifter is the speedometer. On the right side of the shifter is the reverse lock out. Left side front is the reverse lights and just behind that is the CAGS.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 21, 2001 | 11:18 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Not quite correct.
Reverse lights are a standard two-prong weather pack connector. That is the ONLY connector on the right side of the tranny
On the left side of the tranny you have three connectors. The reverse lockout plug is right near the shifter. The VSS plug is below that (and points straight down IIRC). The skip shift plug is farther towards the front by about 6 inches on the left side (near the blank "plate" on the top of the tranny in front of the shifter).
The VSS has its own type of plug; the Reverse Lockout and CAGS plugs are the same.
Here's a picture:
[This message has been edited by 99Hawk120 (edited November 21, 2001).]
Old Nov 21, 2001 | 07:40 PM
Colt's Avatar
Car: '89 Formula
Axle/Gears: 7.625
Thank you gentlemen for your input.
Your help is greatly appreciated.
Tom Milmont
'89 Formula 350
13.2sec@101mph
My Page
AkDrifted
Aug 17, 2015 07:45 PM
Rustyweb7
Aug 9, 2015 03:05 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
