How hard to install rear end.
Old Nov 23, 2001 | 11:27 PM
Screamer27's Avatar
Car: 1986 Monte SS / 1988 Iroc-Z
Engine: LS3 / L98
Transmission: 4l80E / T56
Axle/Gears: 3.73 / 3.45
Ok, I am pretty mechanically inclined, but no astronaught. My friend has a 91 RS, with a LO3, and it has the 2.73 non posi rear end. That car screams posi. While we where out on our journey through a local junkyard today we found a 88 Iroc with rear discs that caught my eye. Also it was a 350 which I bet had the G92, because of the discs, That means the gears are 3.27 gears. I was just wandering since he has drum rears and such, How hard would it be to take this rear end out, and swap it into his, and get the rear breaks to work. The rest of the brake assemblies are there, but i don't know what is invoved in taking them out, or what all I would need, Thanks again for your help.
1994 Camaro Z28. PURE BLACK. Hardtop automatic.
Pics of the Z
1989 Camaro RS. Bright Red/ 58,XXX miles. SOLD
1983 Camaro Sport coupe rusted out blue with green spray paint with black highlights of spraypaint(your get the picture) IRON DUKE 4cyl, Project car for summer.
Mid Iowa Camaro Club Member
ICQ# 39648953
Http://screaminz.50megs.com
Old Nov 24, 2001 | 12:43 AM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
I was wondering also, I've got the drum rear end and was wondering what it would take if I found a 10 bolt with disc. I would guess that it would take probably a new master cylinder, but would I need different brake lines??
1988 Camaro Sport Coupe Convertible.
Carmine Interior, light red exterior. Level 4?? option group.
One of a kind!!
Go here then to pics to see it!
http://crustynun.cjb.net
Old Nov 24, 2001 | 06:37 AM
ede's Avatar
ede
it's real easy to swap rears, everything is a direct bolt up. you'd need the porpotioning valve from the disk car if your car isn't equiped with it. the drum porpotioning valve is a casting while the disk one is machined.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 24, 2001 | 07:16 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Rear End Swap
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
[This message has been edited by GMTech (edited November 24, 2001).]
Old Nov 24, 2001 | 09:46 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
It took me and a friend 3 hours to swap out my rear. We probably could have got it done a lot faster but we took our time and sanded down the new rear then painted it. Its really straight forward.
Old Apr 25, 2002 | 06:22 PM
PopaPork's Avatar
Hey I got a few questions about this rear swap. Do you have to change speedo gears, and if so how do you know which ones to get? I want to go from a 273 to a 342. I read the article but didnt see the answer. Also, how hard would it be to take my 273 and take out the gears and and put in the slp posi and new gears?
Old Apr 26, 2002 | 12:42 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
You will need to change the speedo gears to correct the speedo & pulse signal to ECM. You should already have a red 17 tooth driven gear in there. You need to change to a 44 tooth dark gray drive gear, pn 25513051 & 10456089 sleeve. As long as you hve 28 spline axles you can use the SLP posi. You will have set pinion depth, shim & pattern the gears. Procedures can be found in a good shop manual or you can pay someone to do it. You will need some special tools though.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
BlackBoulder
Aug 11, 2015 11:15 PM
