4th gen posi?
Old Nov 22, 2001 | 09:12 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
4th gen posi?
I am going to the junk yard saturday. There is a 4th gen 93-97 camaro with a disk brake rear end. How do I know it this is posi? Are there codes to check for in the VIN. The axle shafts are out of it so I can't do the spin test. Thanks for your help.
Old Nov 22, 2001 | 09:32 PM
SoCo80p's Avatar
if its a base model it will be open, if its a z-28 it will be a posi.
Old Nov 22, 2001 | 11:05 PM
HotRod's Avatar
Car: 87 GTA
Ok, how else can I tell. I am not sure if this car is a Z or not. Thanks.
Old Nov 22, 2001 | 11:06 PM
HotRod's Avatar
Car: 87 GTA
Sorry, forgot, does it matter that it has disk brakes?
Old Nov 25, 2001 | 06:44 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Check the vin # the 8th digit should be
P for a Z28.P is the letter used ofr the LT1
If the front fender says Camaro the it's a V6,if it says Z28 then it's a V8.
Old Nov 25, 2001 | 08:48 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by HotRod:
Sorry, forgot, does it matter that it has disk brakes?</font>
No, You could check the housing for a tag that says use XXXX limited slip gear oil or spin the rear wheels they should both move in the same direction, one wheel will delay a little bit because its limited slip.
SSC
Orr89RocZ
Apr 25, 2016 08:28 AM
Orr89RocZ
Oct 7, 2015 12:47 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
