Z28 Automatic Transmissions?
Is the automatic transmission used with the base Z28 engine (LG4) the same transmission used with the TPI (LB9) engine?
Thinking of upgrading engines but would like to retain the transmission.
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Z28 Automatic Transmissions?
Your trans will work with any 1st gen. ('65-'99) small block chevy motor, but more specifically you can do what you're looking to do.
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
They may have made small improvements throughout the years but essentially the same thing.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
