what stall converter for a 305 tpi
I have a 305 Tpi motor that is rebuilt and has a cat back exhaust,cam,and I plan on doing headers.Want to know what stall converter i should be using.Thanks
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Your 305 doesnt make as much torque as the 350, so a converter rated at "2500" for a 350 will, in all likelihood, stall at a lower speed on your 305.
That said, I've had good luck with the Turbine Technologies TT2400 piece. I chopped off 4 tenths with it, and it only cost $160.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Daniel Burk
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
match the converter to the cam.. if you have a cam that makes it's power from 2500 - 6000 rpm, obviously you'll want at least a 2500 stall.
another issue is rear gears...if you're gonna be running a 2500 or so stall converter, you're gonna want at least 3.23s, or drivability will suffer a lot
finally, keep in mind the limitations of TPI. Even on a 305, tpi hits a brick wall by 5500 or so, so unless you're gonna do some upgrading of your tpi components, you'll want to stay reasonably mild on the cam, and the rear gears and the converter as well. It all works together.
oh, and one last comment. Rated stall speeds on a converter are not really accurate. on a 305 which isn't a torque monster, a 2500 stall converter will probably be fully stalled before 2500 rpm. On the flipside, my supercharged 350 with 2500 stall convertor stalls between 2700 and 3000.
Sanjay
Aug 12, 2015 03:41 PM
