Flat out answer needed or approximation
Old Nov 27, 2001 | 08:59 PM
89 4Mula 350 Tbi's Avatar
Alright guys i need a flat out answer about swapping out my 700 r4 and putting a manual trans in my car. Now the question is how much do you think it would cost to swap a t5 in or a t56. Also what parts would i need if i'm missing something out of the list Flywheel clutch pressure plate throw out bearing shifter trans center consoleplate pedal assembly hydralic cylinder lines fluid how bout a comp or somethin else thanks a lot in advance oh and is the swap pretty straight foward.
Old Nov 27, 2001 | 10:21 PM
irocaz28's Avatar
been there done that! GOOD LUCK! youre lookin at about $2000 in parts and labor. Good place to start is a junk yard, take out as many parts as you can from this car. Trans, flywheel, bellhousing, clutch(get new), throw out bearing, fork, uppper and lower boot, slave cylinder, clutch pedal assembly and new brake pedal. Buuy a chiltons manual, all the parts are basically listed in there through blow up diagrams. Labor is whats gonna kill you.
Old Nov 28, 2001 | 04:10 PM
Yeah i'm gonna do all the labor my self so i hope it isnt that much also what about drive shafts will i need a new one with either the t5 or t56. Thanks.
Old Nov 28, 2001 | 10:57 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
WOO-HOOOO!!!!! 100 posts!! And it only took me...11 months! I gotta come here more often .
About the tranny swap-go with the T56. Its superior to the T5 in every way and is worth the extra grand or so. Regardless of which you choose, you can use your driveshaft for both transmissions as the cases are all the same length (T5, 700R4, T56, 4L60E).
Either swap is pretty straightforward and there are tech articles on this site for both. An average price for a T56 is about $1500 with everything. If you look around, you can find one for a lot less. I've seen them go for as little as $800.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
