383 w/ 700R4
Old Nov 30, 2001 | 12:37 AM
ChevyRacer83's Avatar
383 w/ 700R4
I'm 18, and probably not as wise as most of you. I've read a couple posts about 700R4's getting blown up under to much torque. I plan on switching out my stock 305 4bbl to a 383. Should I do anything to the stock 700R4 like have it rebuilt with durable parts? What are your opinions? How much torque or horsepower can these 700R4's stand up to?
Old Nov 30, 2001 | 03:55 AM
transfixleo's Avatar
You will have 30 splines and the '88-92 are essentially the same except for calibration differences. What to do?:
TransGo Reprogramming kit and the Hi Rev release springs that come with it. TransGo Hi Rev Pump Ring Kit. 4L60E Input Sprag Assembly and 3-4 pack setup for eight frictions. All Borg Warner High Energy frictions. Corvette rear planetary. NEW GM Sun Shell. Minimum endplay settings. 093 (Vette) Servo. .477" PR Boost Valve. .282 Int/Rev Boost Valve. TruCool LPD cooler and bypass the radiator.
The converter choice depends completely on the power band of the engine. Your stall should be at or just below where your engine STARTS to make power and the WOT shift points should be set so that it is completed BEFORE the power starts to fall off (NOT your max RPM). A top quality converter supplier is Continental: The number for Continental Converters in Inglewood Ca. is 1-310-674-1072
With proper build and parts selection, upwards of 600 HP.
junior419
Apr 7, 2025 11:35 AM
Reddeath210
Oct 6, 2015 08:20 AM
MATEOZ28
Oct 13, 2000 08:31 AM
fly89gta
Aug 1, 2000 01:24 PM
SmokedU
Jul 31, 2000 07:27 AM
