700R4 shift problems after kit
Old Dec 1, 2001 | 04:57 PM
jamesbern's Avatar
I rebuilt my transmission and put a superior 700hp shift kit in it. After I adjusted the t.v. cable I drove it to work (about 50 miles) worked fine, firm shift up or down, after about 100 miles the sucker won't upshift unless it has W.O.T. I have tried different adjustments on the cable, but to no avail. I am looking for other suggestions before pulling it back out.
Old Dec 2, 2001 | 02:30 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Sounds like it could be a governer issue.
Working on:
'84 Z28 LG4 305 with 209,000 original miles!
Dual electric fans (from a formula).
9 bolt posi disc rear with 3.27 gears.
145 MPH IROC Speedo
430 HP 350 (ZZ430) Coming soon! (Building it myself, so I don't get those AWESOME valve covers!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
+ L1 Advanced Engine Performance
+ X1 Undercar Specialist
And....A sig. that's getting way too long!
Old Dec 2, 2001 | 03:23 AM
transfixleo's Avatar
Sounds more to me like the Throttle Valve in the VB is stuck (A Genuine Shift Kit, aka TransGo, FIXES that). You could also have a broken or disconnected TV Cable IF the larger checkball was installed. Do this first: To adjust the TV Cable skip the book method and do this: Press the D button on the adjuster and loosen the cable setting. Now, have someone floor the gas pedal while you check to see if the throttle plate is open all the way. Usually they are off a little and will wiggle. Do whatever you have to do to get it open solid. Now, with the pedal still floored, press the D button and pull the cable casing (the black tube) back as hard as you can and release the button. You now have the engine, tranny and gas pedal all in sync at WOT. Mark the cable so if for some reason it gets moved you can know where to put it again. The problem with the 'self adjust method' is that it bends things and puts them permanently out of whack. It is also the full TV setting, which is theoretically what the GM method does.
Next, if that doesn't help, get a good gauge on it and check and report ALL readings at Idle, Fast Idle and Fast Idle W/Cable pulled full.
Old Dec 2, 2001 | 07:13 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
<font face="Verdana, Arial" size="2">Originally posted by jamesbern:
I rebuilt my transmission and put a superior 700hp shift kit in it. </font>
I never heard of a shift kit making 700HP.
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Dec 2, 2001 | 12:52 PM
jamesbern's Avatar
Thats the name of the shift kit.
Old Dec 2, 2001 | 09:42 PM
jamesbern's Avatar
Throttle valve was stuck in the valve body, will clean it up and repair tommorrow, thank you all for the help.
camaro11j
Sep 19, 2018 08:49 AM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
drathaar907
Aug 6, 2015 04:20 PM
