Rear end swap
Old Dec 2, 2001 | 04:43 PM
rizzo's Avatar
Rear end swap
Would a drum rear end be a direct replacement for one with disc? Im guessing it'll bolt right up but, what about brake lines and the parking brake?
Old Dec 2, 2001 | 04:52 PM
SoCo80p's Avatar
it will bolt in but you will need to run new lines, e-brake cables, swap out the master, and propotioning valve, in other words find another disc axle
Old Dec 2, 2001 | 05:48 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Most of the axles I have seen from the boneyard, or classifieds have the brakelines already on them. You will need e-brake cables though and another prop valve.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 3, 2001 | 06:00 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
I swapped a 9 bolt disc rear from a 10 bolt peg-leg. I had to change the lines just because later models have metric fittings. The e-brake is set up the exact same, I just had to adust it.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
