a fix to the crossmember bolt problem
Old Dec 2, 2001 | 08:18 PM
toosloz's Avatar
wouldn't it be alot nicer and easier to get your crossmember installed with studs instead of the stock crap?
84z28HO
355
open element/k&n
m5/hurst billet plus shifter
83 z28 fiberglass hood
10bolt w/3:42posi
gm aluminum driveshaft
performer intake
performer 600cfm carb
accel 8mm wires
adjustable thermostat switch
160 stat
gta rims
gts blackouts
s.s rear control arms
s.s panhard rod
s.s subframe connectors
98 camaro rear springs,shocks
98 z28 leather seats
95 camaro rear view mirror
"wonderbar"
4th gen z28 tips
14.3@95mph
http://www.geocities.com/toosloz/84camaroz28.html
Old Dec 3, 2001 | 01:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
No.
Old Dec 3, 2001 | 05:58 AM
toosloz's Avatar
you tried it?
Old Dec 3, 2001 | 08:57 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
that's how mine is setup....pretty damn cool....only thing i don't like is i can't just pull 3 bolts and swing it out of the way quick....actually need to pull off 4 nuts.
Old Dec 3, 2001 | 10:09 AM
toosloz's Avatar
i might think about doing this
you wouldn't have to worry about bolt stripping out....and if stainless is used..better yet
Old Dec 3, 2001 | 01:16 PM
five7kid's Avatar
How are you going to mount these studs?
If you use the same welded-in nuts the factory used for the bolts, you really aren't any better off.
My '82 chassis didn't have any provisions for the back two bolts (one on each side) needed for the TH700R4 crossmember. I used the formerly back bolt holes in the frame for the front crossmember bolts, and match drilled new back bolt holes into the frame. Then, I elongated the drain holes at the far rear of the frame members so I could slide a nut & washer up to the bolt holes and screw in the bolts.
Studs would have been a big step up in effort for me. In two years, I've dropped the crossmember once, to drain the tranny fluid. It was fairly simple to disassemble and reassemble, much less work than trying to mount studs.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
ZMWojnar
Brakes
May 12, 2019 10:43 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Elliswon
Aug 10, 2015 12:33 PM
Amillionoh7
Aug 7, 2015 01:24 PM
