rpm's fall while driving, like it was put in nuetral
Old Dec 1, 2001 | 06:15 PM
Mo's Avatar
Mo
Ok, when I'm driving in second and let off the gas, the rpm's drop to like 1000 (from about 2-2500) like I just put it in nuetral. THen when I press the gas again, the engine has to rev back up to like 2500 again before the car will accelerate.
Any ideas?
90 IROC 5.7l (L98)
LIKE A ROC
[URL=http://www.CamaroPitStop.150m.com[/URL]
[This message has been edited by Mo (edited December 01, 2001).]
Old Dec 1, 2001 | 07:22 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Is this while driving in manual second or when in overdrive range, second gear? I assume second range. Sounds like a problem w/ the overrun clutches. Could be burnt or stripped.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 2, 2001 | 12:48 PM
Mo's Avatar
Mo
This happens when I'm in second manually (shifter at 2), I haven't noticed it happening when I'm in drive.
90 IROC 5.7l (L98)
LIKE A ROC
The Camaro Pit Stop
Old Dec 2, 2001 | 01:11 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Thats cause when you let off, it shifts into 3rd. You should have engine braking in manual 2nd (manual 1st and 3rd also for that matter). This engine braking is via the overrun clutches applying forcing the foward sprag to lock up in both directions.
Could have broken the hub that the clutches spline to also.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
[This message has been edited by GMTech (edited December 02, 2001).]
Old Dec 2, 2001 | 03:54 PM
Mo's Avatar
Mo
It shouldn't be shifting into third though, (transgo shift kit), but it doesn't act like its in gear anyway, even if it shifted into third when i press the gas it should react but it doesn't, the engine just revs back up to where it should be and then you can feel it engage again and the car will move.
You used to be able to feel the engine breaking while driving in 2nd ~ 25-30 mph with foot off the gas, but now it doesn't do it anymore when the rpms drop.
But it sounds like the problem may be over my head anyway. Thanks for the suggestions.
90 IROC 5.7l (L98)
LIKE A ROC
The Camaro Pit Stop
Old Dec 2, 2001 | 04:18 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
<font face="Verdana, Arial" size="2">Originally posted by Mo:
It shouldn't be shifting into third though, (transgo shift kit),</font>
In manual second, your right, it shouldn't. I was refering to why I assumed this was happening in manual second vs. overdrive. Had you been in overdrive, it would have shifted into third.
You say it won't do it in Drive (manual 3rd)?
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 2, 2001 | 06:02 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I had the very sae problem in my 89 Camaro. I had the trans rebuilt, did it my self, and all I did was put new seals and clutches in and feels normal again and I once again have engine braking
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
LT1 intake soon...if I can find one!!!
stock TPI for now 24# inj
87 Trans Am GTA 350 TPI
had engine fire
SHE NOW RUNS!!!!
Flowmaster exhaust
LT1 Injectors
LT1 intake also if I can find one!!
Old Dec 2, 2001 | 06:03 PM
AaronIROCZ's Avatar
I had the very same problem in my 89 Camaro. I had the trans rebuilt, did it my self, and all I did was put new seals and clutches in and feels normal again and I once again have engine braking.
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
had engine fire
SHE NOW RUNS!!!!
Flowmaster exhaust
LT1 Injectors
Old Dec 2, 2001 | 07:26 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Did you find anything burnt up? Its possible you had a "rolled" overrun clutch piston seal, although I never seen that one rolled before and teh new seals and clutches cured it. Odd.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 3, 2001 | 02:07 PM
Mo's Avatar
Mo
They drop some in D, but if I press the gas you can feel it start to accelerate so I don't think its a problem in D.
Old Dec 3, 2001 | 08:50 PM
AaronIROCZ's Avatar
Although I had hardly any friction material left on the clutches and the steel was showing through on mostly all of them. My Teacher couldn't beleve that it still moved. I rebuilt it because of had extra time in class and it drove fine no problems.
89 Iroc 350 TPI,
Forged pistions
Flowmaster exhaust
had engine fire
SHE NOW RUNS!!!!
Flowmaster exhaust
LT1 Injectors
Old Dec 3, 2001 | 11:05 PM
Pro Built Automatics's Avatar
All of your problems are in the overrun clutch & overrun sprag area. No matter which is has to come out for it to be fixed. Make sure that whoever does the work that the overrun sprag is updated with the latest from Borg-Warner. As long as it down this far you might consider the Trans-Go Performance Shift kit and updating the 3-4 clutch pack from six to eight Borg-Warner 3-4 Hi-Energy clutches along with a 2-4 BW Hi-E band with a Corvette servo & boost valves. Now you will have a very reliable perrformance unit. If I can be of help let me know as I carry everything for the 7004R.
Hope This Helps!!!
Old Dec 4, 2001 | 08:30 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yeah, what he said. I buy all my "performance" tranny parts from probuilt. Call him up and he will square you away w/ all that you need.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
