If geared properly, a T56 should be as efffective as any other tranny at getting a good launch shouldn't it? Six speeds are just very foreign to me.
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:26 Times in 22 Posts
Yep, its got four forward gears like any other manual trans, but it has two overdrives. Its first gear is 2.66. A T5 is either 2.75 or 2.95, depending on what engine it came with.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
Southern California
Tremec sells T56s with different ratios. They offer the 2.66, 2.9X, and 3.36 first gears. The 3.36 would really help get a car off the line compared to the T5 with 2.95 first. Tremec only rates the 3.36 T56 at 350 ft. lbs.
84 Z28 L69. 5 speed with 3.73 posi (broken)Ported heads, intake, 10:1 comp. 230/230 .480 lift cam @.050" w/108 LSA
Triumph Spitfire SCCA roadracer. 1.1 liter 4cyl w/ 14:1 comp.
turns on rails!
turns on rails!
Just get 3.73, 3.89, or 4.10 rear and you won't have to worry about it being hard to launch.
Get a good Clutch, 3.73 gears, and 2 weeks of practice. and you will be right there, I could launch my T-56 like a bat out of hell. but then it went out
so now im back to 700r4 but I think i oculd still out launch it.
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
so now im back to 700r4 but I think i oculd still out launch it.------------------
91 Z28 5.7l Camaro
more to come....
My 91 Z28
