Pops out of reverse!!! Rebuild kit?
Old Dec 4, 2001 | 11:42 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I can't get my car to stay in reverse. I know I need synchrose, but do I need a new countershaft?
If its just a rebuild kit where can I get one?
Thanks in advance.
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass, 3"cowl, bat. relocate, AC delete, smog delet, cats gutted, stock T-5 w/ 3.42 rear, ported plenum, 24# inj., dual friction centerforce.
Old Dec 5, 2001 | 11:55 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
Anyone? Please help. . .
Old Dec 5, 2001 | 06:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Reverse has no synchro. Even if it was one of the forward gears (which do all have synchros) replacing them wouldn't fix that if they were doing it.
Rebuild kits also won't fix that. Sounds to me like somebody has been shifting it into reverse without putting it into a forward gear first, thereby grinding reverse for several seconds every time; and they've done it so many times for so long, that they have trashed the reverse gears. You probably need all 3 reverse gears. They will cost over $100 apiece; don't get them new, get a junk trans, and get the gears out of it.
You might want to check out www.gearzone.net for some 5-speed info, including a video on how to disassemble and reassemble it. Of course, you will need a rebuild kit to go along with the used hard parts, which the above mentioned place has available.
ICON Motorsports
billybob6110
Feb 11, 2016 10:41 AM
New2Chevy
Sep 28, 2015 12:35 AM
Magman
Sep 13, 2015 08:43 AM
greenyone
Sep 2, 2015 03:39 PM
someone972
Aug 30, 2015 12:52 AM
