auto to manual?
Old Nov 26, 2001 | 09:27 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
auto to manual?
i got a 92Z28 with a 700r4 tranny. I'm sick of the auto and want a 6spd from an lt1 or ls1. what all would i need besides a clutch,
pedals, flywheel, mastercylinder, and the tranny? any help is appreciated
Old Nov 26, 2001 | 09:39 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Hey, you'll also need an aftermarket crossmember from either Spohn Performance or Skulte Performance Design (that link is also a tech article on the swap and there are many more out there).. I went with the Spohn it was a little cheaper at 100$, or there is a few guy's who have actually reused theirs by welding it someway or another I don't know anything about it.. You'll also need a box for the speedo to work correctly, I got the Dakota Digital SGI-5, its about 80$ and works better than any others out there.. You'll want a trannie from 94-97 (93's had a different 6th(?) gear ratio so get 94-97).. LS1 trannie's are different and I don't think they fit period.. I also got an LT1 starter, I read somewhere that you could reuse the auto starter but apparently it didn't work.. Most people also wire their reverse lockout solenoid to the brake pedal so the soleonid is energeized when your foot is on the brake pedal and you can slide it right into reverse, or if you leave it discon. it requires a little force to overcome the spring.. thats basically everything plus what you mentioned, unless I forgot something! Good luck..
Frank
1991 Camaro Z28
CURRENT MODS:
350 TPI, T56 6-Speed, Edelbrock Headers, Runners, & Intake, Flowmaster Exhaust w/ Flowtech Cutout, MSD 8.5mm wires, Cap/Rotar & 6AL Ignition, Autolite Double Platinum Plugs, Random Technology high flow cat, Hypertech Power Chip (160 Deg Thermo), K&N Filterchargers, Homemade RamAir, GTS Taillight Blackouts
STEREO MODS:
Pioneer DEH-P6000, 2 JL Audio 12W3 subwoofers in custom hatch enclosure,
Rockford BD1000.1 Amp, Infinity Kappa 4x6" plates & 6x9's
WEBMASTER: [URL=http://www.thirdgenfbodies.com]www.thirdgenfbodies.com</A>
[This message has been edited by SLAYER6669 (edited November 26, 2001).]
Old Nov 27, 2001 | 07:24 PM
Car: 1992 Z28
thx man, do you roughly know how much this little swap should cost me?
Old Dec 8, 2001 | 06:51 AM
jimbuck's Avatar
Depending on the tranny, 12-15.
I got a tranny, clutch for $950. Then just the little extras. somewhere I have a list of the part numbers and cost from Dal.
It was a pretty easy swap, but I would recommend a couple of things, if you use a used clutch, at least replace the t/o bearing. I didn't and have to do that now. Bearing is expensive $95.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
RyanJB
May 7, 2016 06:23 PM
88rscamar0
Sep 23, 2015 09:08 PM
Magman
Sep 12, 2015 11:55 PM
Isaac McCormick
Sep 12, 2015 10:20 PM
