POP QUIZ! NAME THIS SEAL on 700r4
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
i got a leak, its not the pan, or input shaft, but three things, theres three seals in the picture. name all three, 100 points!!!
Car: 87 trans am clone
Engine: tbi 350 with corvette heads
Transmission: t56
Axle/Gears: 4.11
Re: POP QUIZ! NAME THIS SEAL on 700r4
the biggest one is the trans dipstick tube seal the smallest one is the shift shaft seal and the middle one is the electric pass thru connector seal
dang it, you're good, but i need the speed o seal, cant find one. the trans dipstick seal and TV cable seal i picked up a run down tranny shop. those dudes were dicks. the owner told me to talk to a Mexican dude. (im half Mexican but white dominated) and the Hispanic dude wanted 5 bucks. i was like yeah right i can get those for like 89cents each, then he just waved his hand, "just take em". i even asked dude you sure, take em while walked away disappointed. i had parked around the corner so i just walked away. and that electric seal did seem small for a speedo seal but ill just use it anyways for the connector thingy dude
Car: `86 SS / `87 SS
I've had good luck finding the speedo gear pinion seals at Napa. The outer gear sleeve o-rings I have some from a dealer I think.
The big "top" hat seal is for the dipstick tube. The smaller "top" hat seal is for the TV cable. The small grey seal is for the speedometer housing.......
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
gta892000
Sep 16, 2015 12:37 AM
