Bellhousing cracking
Old Sep 3, 2009 | 09:36 AM
badblackiroc's Avatar
Car: 88 IROC-Z
Engine: L98 350 Built
Transmission: Built 700R4
Ive been having a problem with my bellhousing cracking on my 700r4 in my 88 iroc.
what would cause it to crack all the way across the housing and about 1/4 of the way down the case. i thought it was a fluke at first but its done it 3 times now, and after the 2nd time i had it welded back and i had 1" wide and 5" long braces welded on for added strength but it broke them as well.
so do i have a suspension problem, to much power, or something else.
anybody with some insight on the issue would be great.
thanks
joseph
Old Sep 4, 2009 | 05:35 PM
Grinch Racing's Avatar
Car: 91 B4C 92 Z 93LT1
Engine: L98s & LT1s
Transmission: 700R4s all around
Axle/Gears: 3.23x2 & 3.73
Re: Bellhousing cracking
Are you running solid mounts??
Old Sep 5, 2009 | 03:48 PM
Car: 88 IROC-Z
nope, do i need to?
i have a set of Moroso solid mounts
Old Sep 8, 2009 | 10:00 AM
Pocket's Avatar
Car: 91 Trans Am
Common causes are improper converter installation, excessive vibration cause by too stiff of trans mounts and improperly bolting on the bellhousing
Old Sep 8, 2009 | 07:48 PM
Car: 88 IROC-Z
Im running regular transmission mounts, the transmission was bolted properly.
could the engine mounts have gone bad? could that be where the vibrations are coming from?
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
AUZ28
Oct 3, 2015 06:28 PM
