Speedo pickup removal on T5?
Old Dec 8, 2001 | 12:29 PM
Mubie's Avatar
I've removed the 10mm bolt and hold down for the speedo pickup on the tranny. Now the pickup just spins...is it threaded or do I have to pull it out with a gear puller?? Thanks for any responses.
Old Dec 8, 2001 | 04:16 PM
STOCKROC's Avatar
It should just pull out. Might need to use a pair of plires to get a grip on it. Just took mine out a couple of days ago.
Old Dec 10, 2001 | 08:22 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
It has a rubber "O" ring on it to seal in the fluid. That sometimes makes it hard to pull out. If you do use pliers to pull it out, be careful of the threads that the cable goes to.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
andy74
Sep 3, 2015 08:41 AM
