Differential Vent replacement/question
Old Sep 4, 2009 | 10:35 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Noticed mine is broken. Went to the junkyard and everytime I tried to get one the plastic broke due to it gets fragile over time.
Does anyone know a part number or can I use one from an older rear - say the 8 1/2 rear - or any tricks to help with this? Thank you very much.
Old Sep 4, 2009 | 10:47 AM
big gear head's Avatar
Re: Differential Vent replacement/question
Do you have the 10 bolt or 9 bolt? The 9 bolt uses the same vent as the Mustang 8.8. The 10 bolt uses a plastic press in vent that can usually be easily removed by holding it at the base with pliers and turning it while pulling up. I have some new ones in the shop, but I can't remember the part number.
Old Sep 4, 2009 | 12:09 PM
Car: 1982 Z-28
Engine: 383
Big Gear - thanks for the reply. It is a 10 bolt. I tried the pliers at the bone yard but they break due to the plastic gets hard and brittle.
If you have some at your shop, do most shops? Or would you be willing to sell one of yours?
I see some advertised in the Classic Ind catalog, but they are for either 7/16 or 3/8 (both press in) and are for the older style rears so didnt know if one of these could be used.
Old Sep 4, 2009 | 12:45 PM
I keep them because I build rear ends. That's about all that I do (and a few manual transmissions). I have the old 3/8 and the 7/16 vents, and I will sell you one. Check yours and see what size it is. I think I sell them at about 1/2 the price of the resto parts places.
Old Sep 5, 2009 | 09:18 PM
Car: 1982 Z-28
Engine: 383
Big Gear. I measured and believe it is a 7/16. How much would one be?
Old Sep 5, 2009 | 09:38 PM
I'll try to remember to check the price tomorrow. I think it's about $4 or $5. Takes about $4 to ship.
Old Sep 8, 2009 | 08:44 AM
Car: 1982 Z-28
Engine: 383
Thanks, just let me know.
Old Sep 8, 2009 | 07:58 PM
It's $3.60.
Pac J
May 17, 2020 10:44 AM
dbrochard
Jan 28, 2016 08:42 AM
Fanatic1074
Oct 2, 2015 03:47 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
