How to get converter bolts off flywheel.
Old Dec 12, 2001 | 04:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Any tricks? Dam engine keeps turning on me.
Old Dec 12, 2001 | 04:45 PM
chevyboy07 91's Avatar
Jegs sells a tool to grab the flywheel. Or get a strong friend...they are loose by now and not soo tight to where a friend couldnt grab it and prevent it from spinning.
Also, if you "shock" the ratchet or wrench, they will break free. Meaning don't "pull" on it....kind of "punch it" or a quick yank....i cant explain it LOL...I sound like a dumbass LMAO
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Dec 12, 2001 | 05:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
lol i know what you talking about. I was afraid of snapping something.
Old Dec 12, 2001 | 06:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Use a large screwdriver or prybar in one of the large holes in the flexplate, let it turn until the block (or starter) holds the screwdriver or prybar and keeps the engine from turning.
You can also hook the starter teeth on the flexplate to the block, etc.
Neither one will damage the flexplate.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Old Dec 12, 2001 | 09:01 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I have one of the flywheel holders/turners, but I rarely use it! Most of the time, I just take a dead-blow hammer to the wrench and they come right out (a standard hammer will work). If you do this sort of work everyday, you should avoid hitting the wrench with your hand, as you will eventually lose the feeling in your hand (or damage something, or whatever!)
Good luck!
1992 Trans Am
May 10, 2023 07:19 PM
1984HO
Mar 19, 2021 11:59 AM
deracer
Apr 11, 2016 12:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
