How much horsepower will a TH350 hold?
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I have a stock th350 with a b&m shift kit and is in great shape but i am wondering if i should build it up for my engine. What do you guys think?
1989 Camaro RS, 355 engine, 4 bolt block, 11.5:1 compression, 305 heads--ported, polished, milled, 3-angle valve job, 2.02 intake and 1.60 exhaust valves, Edelbrock rpm valve springs, 1.5 rockers--, Keith Black pistons, solid lifter cam, Edelbrock RPM intake, 750 cfm Holley, Holley Red electric fuel pump, MSD distributor, Turbo 350 w/B&M Shift kit, 3.73 Richmond Gears, Hooker headers, Flowmaster exhaust
My Pontiac's (my babies)
1972 Pontiac LeMans, 2 Door, red with tan top, 350 V-8, Edelbrock Perf. Intake, Rochester Carb, Turbo 350 trans with B&M shift kit, Dual Exhaust
1968 Pontiac GTO, Rust free body, White with Black Interior, Original 4-Speed Car, 400 V-8 engine, Hideaway Headlights, Positraction Rearend
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Mine is still surviving. The weak link is the intermediate sprag (overrunning clutch). It stops the direct drum when shifting from 1-2. It can explode and take out a few parts inside the tranny. Even a stock engine can break the sprag is misused.
I'm upgrading to a TH400 just for a stronger transmission and a transbrake this winter.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
Yeah, i have a turbo 400 that needs a part or two but i don't know if there would be any HP loss due to it being a heavier duty transmission, granted I would get a stronger tranny, but i would have to get another conversion kit and more than likely another driveshaft.
Car: 87 IROC L98
The TH400 takes about 15 more HP to turn plus weighs about 15 pounds more. A TH350 will let you run quicker but the TH400 is better built.
I built my TH350 a couple of years ago and just finished building the TH400 last week. I like the internal design of the TH400 much better.
Transmission: 4L80E/4L80E
<font face="Verdana, Arial" size="2">Originally posted by Stephen 87 IROC:
I'm upgrading to a TH400 just for a stronger transmission and a transbrake this winter.</font>
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 87 IROC L98
The extra cost of having to buy another shifter. Canadian exchange rate sucks right now and I don't feel the car is light enough yet to really take the full advantage from a glide.
[This message has been edited by Stephen 87 IROC (edited December 13, 2001).]
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I have a TH350 in my 70 Nova,behind a 454.
It's manual-only,with 3000 Stall TC and the usual added clutches/steels.So far it's holding up very well,street driven and occasional drag race.About 550HP/500FT/LBs.
(Running hi-elevens)
I do plan on upgrading to a TH400 when it goes, though.
-Rich-
-Rich-
Car: 4
Engine: 6
Transmission: 5
Stephen is right on the money...
If all you have is a small block, then the 350 is plenty even with stock internals. You have nothing to worry about except making sure it's built right.
ICON Motorsports
ICON Motorsports
RedLeader289
May 28, 2019 01:47 PM
350, conversion, drivetrain, hold, horsepower, hp, kit, loss, lost, motor, rating, th350, th400, transmission, turbo
