Rear Axle Question on My Camaro
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
86 Z28 IROC Z. I have an RPO code GU5, which means 3:23 gears, right? The G92 option would have an RPO code of G92, correct?
Oh, and I don't have posi, I'm pretty sure. There's no G80 RPO on my sticker. I'm considering an Auburn unit and possibly 3:73's.
Just got my car a few days ago, finally.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rear Axle Question on My Camaro
GU5 = 3.23 gears
G92 = Performance option
If you don't have G80, you don't have a factory installed posi.
Many cars came with a base code for a gear option. Some were offered a performance option.
Are you sure your car is an IROC-Z or just a Z28? Options vary depending on a specific model, engine and transmission. In 1986, the Z28 with an LB9 305 TPI and A4 had a standard gear option of 2.73. With the G92 option, it got 3.23 gears. The IROC-Z with the same LB9 engine and A4 tranny had a standard gear option of 2.73 and the G92 option gave it 3.42 gears.
If your RPO list says GU5 then you have 3.23 gears which means you don't have an IROC-Z but just a regular Z28. Your car will have 26 spline axles if you decide to buy a new posi. I'd upgrade to 28 spline axles the same time you upgrade the gears with the new posi.
Car: 1995 Formula
Engine: LT1 350
It's weird because it says IROC Z on the dash. I wonder if someone put that decal on the dash or just put in a whole new dash that says IROC Z.
Car: 87 IROC L98
Not hard to do. They could have also installed a center console out of a Z28. Does the VIN number on the RPO decal match the VIN number on the cowl? Do you have RPO B4Z?
1 Post
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
How is the center console in a Z28 different? Do you mean overhead console?
Dash badges are easy to swap. I have the 5.0 H.O. badge, but only because I found it in a JY and it took about 5 seconds to swap with the original Z28 one.
Edit: nevermind, I think I answered my own Q, you mean they could have swapped the console to get a different RPO sticker...
Car: 87 IROC L98
It's possible the car really is an IROC-Z. If the center console was pulled from a Z28, the VIN number on the RPO decal won't match the VIN on the cowl. It's easier to just change the emblem.
I don't know if the 86 models got the IROC-Z decal on the side of the car but again, that can easily be added.
I recommend an Eaton Posi over the Auburn. You will like the Eaton much better, especially if you get an Auburn and it wears out in about a year. The Eaton can be rebuilt and tuned. The Auburn can not.
Car: 1986 Camaro Z28 IROC-Z
Engine: LB9 305 TPI
My 86' IROC-Z has GU5 3.23 & G80 LSD RPO, and it is in fact a LB9 TPI IROC-Z...
Engine: LB9 305 TPI
So why would you post a reply in a thread that has been dead for 4 years? It's pointless.
Engine: LB9 305 TPI
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
no! it is not pointless when you consider just how many people mine this site for clues, info,and things that they aint gonna find anywhere else.to troll is to learn,my friend. and im all for posting answers to way old posts because many many people find what they need just from taking the time to read about it
