a4 to t5 swap
Old Sep 25, 2009 | 07:30 PM
supermariobros's Avatar
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Axle/Gears: 3.73 posi locker ls1 discs
a4 to t5 swap
Okay I got a 89 formula 5.0 tpi and I am buying a 91 camaro tbi 5speed parts car how would I wire this thing up? Any help appreciated
Old Sep 25, 2009 | 09:29 PM
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Re: a4 to t5 swap
anyone?
Old Sep 25, 2009 | 09:44 PM
89Firebin's Avatar
Car: 89 Firebird Formula 350
Engine: 1974 350
Transmission: '84 Trans Am T5
Axle/Gears: Borg warner 3.27
Re: a4 to t5 swap
Ok when you you say "wire this thing up" what do you mean lol?
Old Sep 25, 2009 | 11:05 PM
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Re: a4 to t5 swap
Well the speedo, reverse lights, and neutral saftey switch. My car doesnt have cruise control so I dont have to worry about that. Also do I just reprogram the computer to a stick or what?
Old Sep 26, 2009 | 08:22 AM
89Firebin's Avatar
Engine: 1974 350
Re: a4 to t5 swap
As far as I know,
The speedo from the 91 should be the same as your 89, just unplug from the A4 and plug it back in to the T5. For the reverse lights there is a connector on the left side of the transmission case, just hook the wires from the ??automatic shifter?? up to it. And for the neutral saftey switch some T5s have a neutral saftey switch in the top transmission case cover, but if yours dosent, you just reroute the wires from the again ??automatic shifter?? to the clutch pedal and install a switch so that the car wont start unless the clutch pedal is pushed. The T56 swap thread sticky tells how to wire some stuff. It starts on page 3 post 145. https://www.thirdgen.org/forums/tran...-thread-3.html. Hope this helps.
Ryan
Old Sep 26, 2009 | 08:24 AM
89Firebin's Avatar
Engine: 1974 350
Re: a4 to t5 swap
Oh and I dont think you have to do anything with the computer.
Old Sep 26, 2009 | 03:27 PM
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Re: a4 to t5 swap
Thanks alot man I appreciate it! I cant wait to get this thing started
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
