700r4 swap Questions...
Old Sep 26, 2009 | 08:59 AM
LT-FUN's Avatar
Found a good deal on a semi built 700r4 with convertor and have a few questions about the swap....Im going from a 88 t-5 and 305....the t-5 just could not take the nitrous anymore....
Will all 700r4's have a spot for torque arm mounting?
What flywheel will I need?...just one I can go to the local speed shop and buy....
Also will a t-5 crossmember work?
Anything else I should need? Not sure on how to run a shifter for the auto... Thanks
Old Sep 26, 2009 | 09:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 700r4 swap Questions...
Yes (I assumed thirdgen, my bad).
Flexplate.
Yes.
You may have to swap drive and/or driven gears to make the speedo read correctly.
JamesC
Old Sep 26, 2009 | 09:54 AM
LT-FUN's Avatar
not worried about the speedo since the car is ushually only driven at the track, what flexplate just any from a late model auto v-8 car?
Old Sep 26, 2009 | 09:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
My understanding of the 700R4's is that only those for the f-body's have the torque arm mounts. The Corvette uses a c-beam and the trucks don't use the torque arm.
Although the tail housing can be swapped between them to provide the torque arm mount. Just be aware that the Corvette output shaft is about 1/2" shorter then the f-body output shaft.
RBob.
Old Sep 26, 2009 | 10:01 AM
LT-FUN's Avatar
RBob.
so I would run into some problems with a vette trans...
Old Sep 26, 2009 | 01:32 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Not really sure if this would end up being an issue or not. I've read here that folks have used the 'Vette tranny in an f-body. They moved the speedometer drive gear (uses a different location), and put the f-body tail housing on. Basically the drive shaft front yoke loses about 1/2" of engagement.
RBob.
camaro11j
Sep 19, 2018 08:49 AM
C409
Sep 1, 2015 03:42 PM
Eric-86sc
Aug 24, 2015 09:01 PM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
