700R4 Shifting problems
Old Sep 27, 2009 | 10:19 PM
sathanous's Avatar
Car: 88 Camaro
Engine: 350, 5.7, TBI
I'm new to working on cars and kind of learning as i go so sorry if I've already read the answer to my problem cause there were i few threads i read and just didn't understand...
I bought a 88 Camaro a few months back and flushed it and did a filter kit... but it was too late... third gear stripped out.
Fast forward a few months I bought another 700r4 from a junkyard and got it in. It will get up to about thirty and the rpms will fly up to about 4500 and the mph will creep up to 40 and then if you let off it will shift and then from there on its fine untill you come to a stop again.
I've read something about the cable that runs from the trans to the throttle body... and about the govenor and some springs and pins... any ideas? are those my problems? is this trans screwed too?
Thanks in advance for all your help.
Old Sep 27, 2009 | 10:24 PM
johnnyzombie's Avatar
Car: 1991 z28 camaro
Re: 700R4 Shifting problems
adjust the detent cable its the cable with the clip that runs from your throttle body the other goes to your cruise control
Old Sep 27, 2009 | 10:36 PM
sathanous's Avatar
Car: 88 Camaro
Ok I'll try that in the morning... and no cruise control so I only have the one... so i dont get confused
Old Sep 27, 2009 | 11:44 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's not a detent cable, it's a TV CABLE - there's a tech article on adjusting it properly - unless it's done right, you can fry the tranny quick.
Old Sep 28, 2009 | 01:49 AM
Detent...tv cable either way it has to be adjusted have someone push the gas to WOT adjust the cable to snug there should be
1/8th inch of slack when the throttle is closed that should help
Old Sep 28, 2009 | 09:18 AM
sathanous's Avatar
Car: 88 Camaro
thanks for poiting me to the article - Adjusting your TV detent cable - running out to do that now.
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
g.l.mos
Aug 22, 2015 12:02 AM
TreDeClaw
Aug 14, 2015 06:58 PM
