T56 connector. cant figure it out for the life of me.
Car: 1989 iroc-z
Engine: mildly built TPI 350
Transmission: 97 T56
Axle/Gears: 3.73 posi
ive been searching on google for almost an hour and i cant find what this pigtail connector is for.
its for a T56 from a 97 camaro i need to do the wiring for.
i have three connectors, two of which i know what they are.
the VSS, reverse lockout, and then this mystery one with only one wire coming out of it.
can anybody help me with this?
gm part number 12101763
acdelco pt170
i also posted this in the electronics board since its kinda both.
acdelco pt170
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Re: T56 connector. cant figure it out for the life of me.
There is a VSS, Reverse lockout, and a Backup - lamp connector. however, the backup lamp connector should also have 2 wires coming out of it.
Car: 1989 iroc-z
yea ive got the first two, and i do need to figure out how to get the reverse lights hooked up but i guess i didnt grab the connector for that.
its like a 10 or 12 guage wire if that helps.
ill post a quick picture of it in just a minute.
Car: '88 GTA
Engine: L-98
These should be all the connections. The weatherpac connector you have pictured doeant look to be to anything on the t-56...
EDIT- after running the part number on rockauto it seems the connector you have is a "glow plug connector". Definitely not for a t-56
Car: '88 GTA
Engine: L-98
one more thing.... from the sounds of it your still missing the "backup switch" connector.
Car: 1989 iroc-z
finally! someone with a picture!
yea i hooked up the vss and its "working," it just said i was going 140 in first gear around my block. i just got the switches on the box the wrong direction, and the car didnt feel like starting again after i fixed it.
what is the CAGS connector and what does it do?
and yea i do need the backup lights still.
anybody got part numbers for either?
Car: '88 GTA
Engine: L-98
the back up light I dont have a number for but you can get it here- http://www.eficonnection.com/eficonn..._pigtails.aspx
Car: 1989 iroc-z
oh ok cool.
once i find the part number ill just have my dad pick it up at a dealership with his amazing work connections.
Car: '88 GTA
Engine: L-98
Car: 1989 iroc-z
dang, your almost too helpful.
thanks.
love the avatar, btw.
thanks.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
CAGS = Computer Aided Gear Shift.
When you try to shift from 1st to 2nd at part throttle it locks out 2nd and forces the shifter over into 4th. It's a PITA! one of the first things I got rid of in my 4th gen.
I dont' remember a 1 wire anywhere on my T56, but it has been a bout 2 yrs since I changed my clutch. If you don't figure it out, let me know and tomorrow I can get under my T/A and see if I have a 1 wire connector on the trans anywhere.
Car: 1987 Pontiac GTA
Engine: 350tpi
Transmission: t56 6 speed
Axle/Gears: 3.70
that kinda looks like a connector for the auxilary fan switch on the passenger side head that kicks the fan on and off.
Car: 1989 iroc-z
i think the guy at the dealership just put the wrong part number in.
the only thing left that i need is the reverse lights.
i do believe i have it all figured out.
now i just have to get it all wired up.
ill probably be able to figure it out, but if anyone feels like telling me the wires and everything that go to the reverse lockout and reverse lights on an 89 iroc before i get under there again, it would be helpful.
Yes
CAGS = Skip Shift = super annoying.
morrow
Jan 13, 2024 12:29 PM
