Mechanical to Electronic Speedo trans adapter
Old Oct 5, 2009 | 01:18 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
i currently have a mechanical speedo in my 83 Bird and i'm interested in converting to an electronic speedo. my question is what adapter would i need to do the conversion? i have a 700r4 trans.
Old Oct 6, 2009 | 10:46 AM
Re: Mechanical to Electronic Speedo trans adapter
anyone?
Old Oct 6, 2009 | 11:41 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
You need an electronic vss and the associated gear to match your rear end. Youll also need a little yellow box found on pre 1990 firebirds with an electronic speedo that is found right with the ecm underneath the passenger side dash.
I converted the mechanical speedo and 82-85 style gauges (boo ralph nader) in my 1984 trans am to a complete cluster and electronic speedo from a 1987 bird a few years ago. I can probably dig up pictures and help you out if that's your goal. It was well worth it to get the later style gauges (still some of the best night time lighting on gauges Ive seen) and the 120mph electronic speedo, the down side was I never got around to getting the correct gear to get the speedo to read correct and it was a 5k redline/6k tach cluster going into my l69 which was a 6k redline.
Old Oct 6, 2009 | 04:02 PM
thanks for the info. i'm not using a stock electronic speedo- i'm going aftermarket, so i don't think i would need all that stuff. shouldn't i just need an adapter to go from the speedo cable output on the trans to the speedo?
would something like this work?
http://www.summitracing.com/parts/SUM-G2887-1/
Old Oct 6, 2009 | 06:11 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
I would assume that would work, your best bet is to call summit and ask if it would work for sure though.
Ya that should be all you need for the aftermarket speedo, at least a summit one as it says on the page but once again Im sure they can tell you for sure if itll work with your speedo.
Jorlain
Aug 24, 2022 05:11 PM
stalkier
Aug 21, 2015 01:54 AM
Elliswon
Aug 10, 2015 12:33 PM
beachrodder
Aug 7, 2015 04:27 PM
