TH350 Swap Question
Old Oct 7, 2009 | 11:52 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
TH350 Swap Question
For a friend, I am swapping a 700R4 for a TH350 shortshaft. He's also got the jegs adj torque arm for the swap. My question is that if I get the driveshaft lengthened by 3 inches, I should be ok, right, because if I remeber right, the long shaft is 9" and the short is 6".
Old Oct 7, 2009 | 03:39 PM
gunner1204's Avatar
Car: 1987 Camaro Z28
Engine: 355c.i. Carb.
Transmission: TH350
Re: TH350 Swap Question
I'm doing the exact same thing with my '87 Z-28 and yes you will have to get those extra inches in the driveshaft i dont think it is exactly 3 inches though its more like 2 3/4 but the machine shop will know when you talk to them. As far as i know that is it I'm waiting on my driveshaft to be done so i will know more this weekend
Old Oct 7, 2009 | 06:07 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
what are u guys mounting your torque arm too? th350 swaps need a bracket that bolts to tailshaft and to the tranny mount for the torque arm.
Old Oct 7, 2009 | 08:11 PM
gunner1204's Avatar
Transmission: TH350
I'm using Duct Tape, I figure 3-4 loops will do the trick...
but if that don't work the B&M mounting bracket I bought from jegs for a crisp benjamin should be suitable given the Duct Tape fails.
Old Oct 8, 2009 | 03:17 PM
82TA_JAIME's Avatar
Car: 92 Camaro RS
Engine: 305 L03
Axle/Gears: stock
^ lol. i'll assume he was joking.haha
Old Oct 8, 2009 | 07:28 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
alright smartass.
Old Oct 9, 2009 | 06:40 PM
dellman83Z's Avatar
I used the hurst torque arm kit, but the shaft actually needs to be about 4" longer. I assumed three inches because of the case difference, but after getting one made to three, it was a bit short for me, it went into the trans fien, but it left too much out for my taste. I guess I will chalk it up to experience to measure before having that done again.
Old Oct 9, 2009 | 09:54 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
82 Z28 driveshafts work but they are getting hard to find.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
