What tq arm mount do i need to put in a th350?
Old Oct 17, 2009 | 12:49 PM
ranger77's Avatar
Car: 82 firebird
Transmission: i believe 200c
Axle/Gears: 3.43 Posi
Well I cant find the correct tq arm mount i did find this however.
http://www.summitracing.com/parts/BM...9/?image=large it looks like it would work it says it works in the 200c at first then says 2004r which confused me since i dont want to spend 100$ on a thing that doesnt work.
Currently i have a 200c transmission in and am wondering what is the correct torque arm mount i will need to put in a th350
Old Oct 17, 2009 | 04:03 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: What tq arm mount do i need to put in a th350?
Thats the right one. You shouldnt need that piece for the cross member because I think the trans are the same length and your cross member is fine. Not quite sure how that piece for it would work either.
Old Oct 17, 2009 | 04:44 PM
ranger77's Avatar
Car: 82 firebird
ty for response you answered my other post about replacing the xmember good thing i dont have to. TY for your response.
Old Oct 17, 2009 | 09:12 PM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
I have that B&M kit, makes for a good pain in the rear in terms of the speedo housing that uses a a hold down clamp, not a lot of fun to remove & replace. If there were length problems with a torque arm, my suggestion would be to fab up a mount and weld it to the tranny crossmember/trans tunnel.
Terrell351
Jun 13, 2021 01:13 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
3rdgenparts
Aug 8, 2015 07:09 PM
