700r electronic speedo to cable conversion
Car: 1986 Iroc, 89RS
Engine: 350 tpi, 350 tbi
Transmission: 700r4,700r4
Axle/Gears: 4.10,2.73
I have an '86 iroc with a cable speedo
the tranny is a '93 700r (electronic speedo).
I also have an '86 firebird (parts car) with an electonic speedo.
I thought that I could just replace the speedo gear case with a mechanical one, but it wont work. Does an electronic speedo use a different tail-housing?
Will the one outta the firebird work?
Or will i have to get a new tailhousing?
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
Re: 700r electronic speedo to cable conversion
I replaced a 86 mech speedo gear in 700r with an electrical speedo gear out of 90 700r with no problems, direct fit. I did not change tail housing but it is also a direct fit. I am not sure but yours maybe a 460le instead of 700r I think they came out in 93 but not sure.
thanks for your help, what happened is that i have the wrong speedo gear (housing). The gears "will" fit as long as you have the correct speedo gear housing
Mods can delete this thread
thank you.
thank you.
topteam54
Oct 6, 2015 12:21 AM
86White_T/A305
Sep 21, 2015 05:28 PM
gta892000
Sep 16, 2015 12:37 AM
700, 700r, cable, change, conversion, electrical, electronic, gear, gears, remove, spedo, speedo, speedometer, trans, transmission, working
