Slave cylinder bleed screw?
Old Oct 20, 2009 | 01:47 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I'm almost 100% sure I have air in my clutch hydraulic system, it works fine until the car heats up to operating temperature and then the clutch begins to not fully release (release clutch plate, fully depress pedal) so it makes sense that air is in the system, but I can't seem to find a bleed screw on the slave cylinder, does anyone know where it is?
Any help is greatly appreciated.
Old Oct 20, 2009 | 02:08 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: Slave cylinder bleed screw?
Its on the top of the slave cyl. right next to the hydro. line. it doesnt look like a brake blead screw so you may have missed it, it uses an allen key also.
Old Oct 20, 2009 | 06:19 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
ah, that makes perfect sense, it being an allen screw, I know exactly where it is now, thanks a lot.
Old Oct 20, 2009 | 08:57 PM
Engine: 350TPI/ S50
No problem, anything to help a fellow Third Gen enthusiast.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
84redta
Sep 19, 2015 09:58 AM
armybyrd
Sep 15, 2015 06:06 PM
dimented24x7
Sep 6, 2015 03:51 PM
