4l80e
Old Oct 25, 2009 | 08:11 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
4l80e
Has anyone tried or put a 4l80e in their 3rd gen? What can I expect if I try and put one in? I know I will have to make trans mount different on crossmember. But as far as fitting next to floor pan, will I have any mods to do?
Thanks Dusty
Old Oct 25, 2009 | 08:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 4l80e
Lots. It's a big heavy transmission.
As always, it's suggested that you use the search function to find other threads related to your question. It's not the first time it's been asked.
Old Oct 25, 2009 | 08:58 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: 4l80e
Thanks Stephen, I used the search function and only got one article by Mac (installing 4l80e)
Old Oct 25, 2009 | 09:01 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: 4l80e
My bad I put 480le instead of 4l80e. Thats why I got only one answer by Mac
Old Oct 26, 2009 | 09:17 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: 4l80e
search topradman's user profile. He had a long article with pictures about what he did to get one in his IROC. The 4L80 is a very heavy duty trans, from what I know it's the same guts as a TH400 just with adjustable line pressure
Old Oct 26, 2009 | 09:32 PM
DSmith's Avatar
Car: 1989 Camaro
Engine: 383
Re: 4l80e
My dad has one in a work truck that had just been rebuilt when the engine chunked a rod. If you are interested I can see what he would take for it. The truck is in Philadelphia Ms
AlkyIROC's Avatar
Car: 87 IROC L98
Re: 4l80e
About 80% of the internal parts are the same however the electronic valve body makes the valve body much bigger. Add in the OD and the tranny becomes bigger.
Estimated weight of a complete 4L80E is around 250 pounds. A TH400 is only 130. My powerglide is around 95
Old Oct 27, 2009 | 12:38 AM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: 4l80e
as a builder building the guts all the way up to the overdrive section is approximately the same as a th400. After that it changes a lot. In all I'd say approx. 60% is the same at best. Seen a lot of 4L80E's lately with no reverse engagement. sad . but fixable.
Old Oct 28, 2009 | 08:40 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Re: 4l80e
Thanks for the replies I have also read its only 40lbs heavier than 700r, but I have all 3 and will put them on a scale then I will know. The reason I am interested is the heavy duty (withoverdrive) if weight is such a big deal I can always ditch someother part of the car.Just wanting one of the best long term strongest tranny to fit in a 3rd gen car.
oldred95
Mar 19, 2020 03:03 PM
ZZ3Astro
Aug 13, 2019 12:57 AM
zride91
Aug 22, 2008 10:53 PM
Vortex91
Jul 19, 2007 08:28 PM
Hoss50
May 30, 2004 12:08 AM
