What trans should I put in?
Old Nov 4, 2009 | 08:45 AM
Alboz28's Avatar
Hi, I am kind of new to camaro and was thinking about buying a 1987 iroc z with a 350 tpi in it, but the tranny is completly garbage. I need help deciding if I should just buy a used 700r4 or should I get a new th350 tranny. By the way, i don't have alot of money at all to spend so any response will be helpful, thanks.
Old Nov 4, 2009 | 08:54 AM
IROC_U's Avatar
Car: 1991 Z28 Camaro
Engine: 355 sbc
Axle/Gears: 4.10
Re: What trans should I put in?
i would put a 4L80 but thats just me, the 700r4 is just not that good of a tranny, i just had to rebuild mine and next time it goes out (and i know it will cause they just cant handle a lot of power very long) im just gonna put a 4L80 in just my $.02
Old Nov 4, 2009 | 10:28 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
For a stock to mild 350 tpi a 700r4 can be built to handle the horsepower no problem. If you want to go a th350 route you lose overdrive and have to buy a mouting kit and get the longer tail to make it work. Both the 700r4 and th350 are just as strong as each other when properly built. the 4l80e is over kill for a stock 350tpi.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
