Problems Throw out bearing?
Old Nov 5, 2009 | 01:49 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Trying to install a T5. and it won't go in. I wiggled and jiggled. and all that. When i pull it off it seems the throwout bearing his hanging up? Do i need a second person to pump the pedal or what? any suggestions please.
Old Nov 5, 2009 | 02:05 PM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: Problems Throw out bearing?
it usually takes 2 people to hold the tranny and wiggle wiggle wiggle lol did yu use a a clutch pilot tool to alighn the clutch when you installed it??
Old Nov 5, 2009 | 02:18 PM
berlin305's Avatar
yea. Still no luck. only one guy doing it.
Old Nov 5, 2009 | 02:19 PM
berlin305's Avatar
i took out the throw out bearing and slide it on the shaft and its probably the colprit because it slid on once then tried it again and got stuck had to wiggle it. last night i got the whole thing on and only 1/4 inch to go and it wouldn't budge no more bleh. Any suggestions more lube by putting on the input shaft?????
Old Nov 5, 2009 | 03:27 PM
berlin305's Avatar
WOOT FINALLY GOT IT IN.
Old Nov 8, 2009 | 05:51 AM
tom86iroc's Avatar
Car: 1986 iroc
good job DON'T put to much lube on the input shaft you will only throw that around onto the clutch and make it slip and junk after that
Old Nov 8, 2009 | 03:25 PM
berlin305's Avatar
Yea i barely put any on what i did was lube it and then took a rag and wiped it off so it had very little on it.
Infested
May 22, 2018 11:56 PM
lt1z350
Sep 29, 2015 01:50 PM
dyeager535
Aug 28, 2015 08:10 AM
Bert87
Aug 23, 2015 03:50 PM
rsrmoore
Aug 7, 2015 08:44 PM
