is my drive shaft bad or my trans
Old Nov 5, 2009 | 06:52 PM
bjm1206's Avatar
Ok at about 50-55 my car starts shaking like no other, it feels ok until i hit 55. Any ideas what this may be. I also would like to add I replaced the u joints. And while I had the drive shaft off the PO had hose 2 hose clamps near the trans. I dont know what this is about, may be a cheap balance act. any ways i took them off, it didnt seem to make a difference.
Old Nov 5, 2009 | 08:35 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: is my drive shaft bad or my trans
Most likey cause is the tires are out of balance, i wouldn't suspect the tranny going bad inless it is making noise or shifting funny. It could also be that the driveshaft is bend or out of balance. Have you hit any pot holes/speed bumps to fast or run over anything to aggresively?
Old Nov 5, 2009 | 09:15 PM
bjm1206's Avatar
no i have not hit anything hard and the wheels and tires are brand new they only have like 30 miles on them
Old Nov 5, 2009 | 09:18 PM
Engine: 350TPI/ S50
Did this shaking happen before or after the new tires?
Old Nov 5, 2009 | 09:28 PM
berlin305's Avatar
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Its the u joints. You will need to replace. Try this when you put it in gear do you hear kind of a faint clunk in the rear end? and when you drive it vibrates not constant but high vibration to low vibration if it does this. The u joints need to be replaced. I had the same problem.
Old Nov 5, 2009 | 09:39 PM
Engine: 350TPI/ S50
That could be it too, I would check that also. A quick check would be to roll on under and see if the have any play in it, with the drive shaft still installed you shouldn't be able to feel any play in the u-joints. I've seen people drive around and not even notice a vibration from u-joints that have long lost their needle bearings. True story when me and my brother tore his 4x4 chevy apart i took the driveshaft out and the endcaps were broken in half and he said, " so that must have been the drive vibration i felt". LOL. The vibration you explain seem like something worse though like a bend driveshaft or a realy off balanced tire.
Old Nov 6, 2009 | 02:01 AM
bjm1206's Avatar
The brand new wheels and tires were on the car when i bought it i noticed the vibration when i test drove it, the PO said that his mechanic said that it was the u-joints, so i replaced them, thats when i noticed the hose clamps on the drive shaft, not sure what they were on there for. So I took them off, and it did not make a difference. It shakes so bad that the cd player skips and everything in the whole car rattles.
Old Nov 6, 2009 | 02:41 AM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
When I first got my car It did this.I got new tires,new rims,had the front end checked and started rebuilding it.Of course the last thing I did is what made it go away.Ball joints were my problem but it could be anything anyone has listed.My vibration was about 70 mph.I also recently had some older tires on my car and got a vibration.Bought a new set of tires and alignment and was like a new car.
Old Nov 6, 2009 | 02:59 AM
MADMAXGTA's Avatar
Car: 89 TTA
check for wheel weights on the tires.
Old Nov 6, 2009 | 10:33 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well I dont think its the u joints. These cars are prone to driveshaft issues. Take the ds out send it to a driveline shop for ballance. Mine was so far out of whack it wasent funny. Actually had 2 dirve shafts ballanced for my bird for the different transmissions ive had in it.
Old Nov 6, 2009 | 01:01 PM
bjm1206's Avatar
Thanks i will do that over the winter
Old Nov 6, 2009 | 01:43 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Check into balancing the drive shaft & pinion yoke together. Worked great on my car.
Bill
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
