Saving a slipyoke
Old Nov 7, 2009 | 11:25 AM
Guest
Guest
Posts: n/a
Saving a slipyoke
I've done this several times over the years, with no problems yet.
Old Nov 7, 2009 | 11:26 AM
Guest
Guest
Posts: n/a
Re: Saving a slipyoke
WD40 works just as well.
Old Nov 7, 2009 | 09:19 PM
toomany's Avatar
Looks good. As long as there is no pitting on the surface there shouldn't be any problems. Pitting will tear up a seal in no time. Slip yokes do wear out over time too. I wrap my spare slip yokes with tape to prevent rust from forming, also helps keep stuff off the inside splines.
Old Nov 9, 2009 | 12:13 PM
Guest
Guest
Posts: n/a
All good thoughts, but rusty is how they tend to be when you buy a used driveshaft. be sure to measure the outside diameter in several places, after you get it shiny, to be sure it's worth paying for.
Old Nov 9, 2009 | 07:43 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
I usually smear axle bearing grease on it to keep it from rusting when i set driveshafts aside. on the spines too so they don't rust either.
Old Nov 9, 2009 | 09:55 PM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
They also make a sleeve that is pressed onto the yoke and will make it look like brand new
Old Nov 10, 2009 | 11:21 AM
Guest
Guest
Posts: n/a
Like the ones for harmonic dampers on engines, right? I didn't know they were offered for slip yokes.
Old Nov 10, 2009 | 12:01 PM
572_Rat's Avatar
Exactly, I used them years ago, when I was working in the industry
92projectcamaro
Dec 8, 2015 12:25 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
