Speedo drive gear problem
Old Nov 7, 2009 | 12:03 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Alright, so the car has been in storage for a long while and the speedo worked fine. Now it does not. I pulled the driven gear to get a look, and it seems that the drive gear slipped up the shaft. I did all of this a long while ago, so I don't remember if I had a new clip or not. What is usually causes this so I can prevent it from happening again? I read a bad speedo cable can cause it? I can manually spin the end of cable, and the speedo moved, so It seems that the cable is fine. The only other thing I can think of is my torque arm came loose, and either the tail shaft or the torque arm were slamming into the bottom of the car under acceleration, or if I shifted too hard.
Anyways, I need to fix this, so can I take the tail shaft off with out removing the trans? And where can I get a new clip if mine is mangled?
Old Nov 7, 2009 | 02:30 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo drive gear problem
Check the first post in the following link for how-to's that may be helpful:
https://www.thirdgen.org/forums/tran...ve-driven.html
You may be able to purchase a new clips from PATC (I'd phone):
http://www.transmissioncenter.net/sp...____va.htm#350
JamesC
Old Nov 8, 2009 | 08:24 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
James, I want to commend you for always helping out without YELLING use the search, because the search is simple sometimes and worthless on other times
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
zeitghaist
Aug 18, 2015 07:33 AM
beachrodder
Aug 7, 2015 04:27 PM
