ford t5 fit in chevy
Old Nov 11, 2009 | 04:01 PM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
hey im buildin up my 91 and puttin a 350 in wit a lil extra power. n i no chevy t5s blow big time and i kno the ford t5s hold up alot better. does any1 no if the ford t5 would work. i kno theres gana be some modifying but llike what.
Old Nov 16, 2009 | 02:02 PM
Guest
Guest
Posts: n/a
Re: ford t5 fit in chevy
I hate to tell you to do a search, but I've seen this discussed at length more than once in the last year. Long story short: give it up. You'll spend more to do the swap than it takes to just get the correct T5.
Old Nov 20, 2009 | 05:36 AM
Pat Hall's Avatar
Just to add to what Jamie said, the Ford T5's aren't any better/stronger than the GM ones anyway. The only reason they hold up longer in the Mustangs is it's a lighter car and the Ford 5.0's don't have as much torque as the Chev 305/350.
Old Nov 20, 2009 | 05:40 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Not to mention, the GM T5 does have a bigger input shaft, so that would make it stronger if everything else were beefier.
Old Nov 20, 2009 | 10:55 AM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Along with every thing else every one else said, the Ford t-5 has a different bellhousing to trans. bolt pattern so you cant bolt a chevy bellhousing to a ford trans. as well as the tailshaft is different. Their is nowhere for the torque arm and the shifter is to far forward.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
Street Lethal
Sep 7, 2015 01:09 PM
Reborn756
Sep 4, 2015 03:42 AM
vortech305
Mar 8, 2001 07:57 PM
