trans problem
Old Nov 17, 2009 | 12:53 PM
sablemaniac's Avatar
Car: 1982 Trans Am
Engine: LG4
trans problem
hello all. new member here and i just bought my first f-body. well actually im going to pick it up saturday.
it's an '82 trans am with the lg4 with auto and im not sure what transmission is in it. the car runs and drives but i have a couple questions on the transmission.
the tranny has no second gear. when driving the car in order to get it into third gear you have to let off the gas and it goes into third with no problem and no slipping at all. the guy im buying it from said he took off the quadrajet and put an edelbrock carb on it. do the autos in the car have a vacuum modulator on them to cause this and it wasn't hooked up after switching carbs? he didn't say it started when he swapped carbs.
also if it does indeed need a rebuild im not afraid to try it cause i have all winter to get it done.
Old Nov 17, 2009 | 02:31 PM
Guest
Guest
Posts: n/a
Re: trans problem
at this point, the original TH200C trans could be long gone. It's easy to replace it with a TH350. From the symptoms, it sounds to me more like it should have a 700R-4 swapped in, but those don't use vacuum modulators.
Old Nov 17, 2009 | 11:58 PM
Car: 1982 Trans Am
Engine: LG4
Re: trans problem
i haven't gotten the chance to look at what tranny is in there yet, i'll have a better look on saturday.
Car: 1982 Trans Am
Engine: LG4
Re: trans problem
i haven't gotten the chance to look at what tranny is in there yet, i'll have a better look on saturday. i wasn't sure if it was vacuum related or if the trans needed a rebuild.
Old Nov 20, 2009 | 05:24 AM
Pat Hall's Avatar
Re: trans problem
Back when I used to own a 2nd gen with a TH350, whenever the vacuum line to the modulator became disconnected, the motor would wind up to about 4-5,000 rpm and then shift with a damn hard bang. But it seems like I also remember that it'd shift if you let off the gas for a second. Either way, it's not hard at all to check and see if there's a vacuum line leaking or disconnected from the trans. Hopefully that's the problem since it's way cheaper and easier to fix versus having to rebuild the trans. Being an '82 there's a damn good chance it's vacuum modulated.
Old Nov 20, 2009 | 12:39 PM
Car: 1982 Trans Am
Engine: LG4
Re: trans problem
i'll see if it has the vacuum modulator on there. tomarrow i will find out what transmission is in there.
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
gta power
Aug 13, 2015 06:15 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
