86 2wd blazer 700r4
Old Nov 18, 2009 | 06:21 PM
mrowles89's Avatar
Car: 1985 iroc-z
Engine: carb 350
86 2wd blazer 700r4
will it work in my 1985 iroc? or would i be better off rebuilding the one i have?
Old Nov 18, 2009 | 09:21 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: 86 2wd blazer 700r4
it would reqire switching the tailshaft housings. not a big job to do pretty easy. i'm not sure of this but i know some latter irocs came with an auxilliary valve body, by switching to a blazer 700r4 you may lose that. but you may not have one so you wouldn't lose any thing so. Short answer yes it will work if you switch the tailshaft housing.
Old Nov 18, 2009 | 10:21 PM
mrowles89's Avatar
Car: 1985 iroc-z
Engine: carb 350
so what do i need to look for on the transmissions to figure it out?
the one from the blazer is in good condition because they're putting in a 350/350 combo
and they told me $50 takes it so i'm really hoping it'll work
Old Nov 18, 2009 | 11:22 PM
Engine: 350TPI/ S50
To see if it has an auxilliary valve body you would have to take the trannsmision oil pan off. they only came on camaros and corvettes and not all of them had it. But for $50 and it works i would buy it. it will work in your car no matter what as long as you switch the tailshaft housing. because the blazer trans won't have the bolt holes forthe torque arm, that is why you need to switch the tailhousing. like i said before not hard to do.
Old Nov 19, 2009 | 06:28 PM
mrowles89's Avatar
Car: 1985 iroc-z
Engine: carb 350
cool i appreciate the info. and the blazer trans is just a place holder to get it back on the road until i get the other one rebuilt.
Old Nov 20, 2009 | 07:02 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The tranny from a 2.8 ANYTHING will not fit your V8. The bell-housing bolt pattern is not the same and you will not be able to bolt any 2.8 tranny to a SBC engine.
Old Nov 20, 2009 | 10:51 AM
Engine: 350TPI/ S50
When did he say it was a 2.8? I assumed it was a 4.3l V6. He never specified whether it was a 2.8 or a 4.3.
if it is a 4.3l it will work if it is a 2.8 or any other 6cyl or 4cyl. other than a 4.3L it will not work.
Old Nov 20, 2009 | 01:12 PM
John in RI's Avatar
I noticed that the title was "86 2wd blazer 700r4". The 4.3 wasn't introduced till well after that.
I Just had to scrap my 91 Blazer last week; I beat the hell out of that truck for over 200K........... RIP !
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
