Stall to much?
Old Nov 11, 2009 | 07:15 PM
xbox07's Avatar
Car: 86' Z28
Axle/Gears: 2.73 (for now)
Stall to much?
Today I got my car back from having a rebuilt trans put in. I had a B&M shift kit put in it and a 2000 stall. It may be something in the trans but now the car feels sluggish it feels like it has less power and the throttle response feels slower than before. Would this be the stall? If so i think i'll have it taken out because the car doesnt feel nearly as sharp. Any advice?
Old Nov 11, 2009 | 07:24 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: Stall to much?
What cam?
Old Nov 11, 2009 | 07:38 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
Re: Stall to much?
what cam? if fairly big. might need a bigger stall.
Old Nov 11, 2009 | 07:40 PM
xbox07's Avatar
Car: 86' Z28
Re: Stall to much?
Nope its a small cam, bearly noticeable not sure on the specs exactly it was in the car when i bought it.
Old Nov 11, 2009 | 07:48 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: Stall to much?
Something seems off. Some people on here put in 2600-2800 stalls on their l98s and dont complain it real sluggish.
Old Nov 11, 2009 | 07:57 PM
xbox07's Avatar
Car: 86' Z28
Re: Stall to much?
Could there be something wrong with the stall? If not i guess its the trans, its been in the shop for a few weeks already. The shop that built the trans did a crappy job and even managed to leave parts out, there was trash in it that stopped up my trans cooler and caused the governor to stick. After a few weeks of messing around with the shop that built it the mechanic actually had to pay someone else out of his pocket to rebuild it and install another shift kit.
Old Nov 11, 2009 | 08:07 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Re: Stall to much?
It would be helpfull if you could find your cam specs. It is important to make sure to match the converter with it. A 2000 stall converter shouldnt be too big, IIRC I think the stock was around 1,600 to 1,800.
From what I've been told the B&M shift kits are junk. If its anything like the transgo kits the tranny guy may have screwed up the valve body when hogging out some of the passage ways. I would wait for Dana from ProBuilt to chime in, or maybe give him a call to try and help diagnose your situation.
ProBuilt Automatics
https://www.700r4l60e.com/
Dana - 909-795-1876
Old Nov 11, 2009 | 08:13 PM
xbox07's Avatar
Car: 86' Z28
Re: Stall to much?
All i know is i've spent over a grand and it ran better with the old trans.
Old Nov 11, 2009 | 11:12 PM
xbox07's Avatar
Car: 86' Z28
Re: Stall to much?
Would my gears affect it? Its got 2:73's. I was told the cam sounded like 440 lift and 270 duration, but i don't really know anything about cams.
Old Nov 12, 2009 | 12:06 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Stall to much?
could it be starting in 2nd gear?
Old Nov 12, 2009 | 12:09 AM
xbox07's Avatar
Car: 86' Z28
Re: Stall to much?
It was before but no i made sure its down shifting every time.
Old Nov 12, 2009 | 12:20 AM
Re: Stall to much?
are you saying the rpm is increasing but the car isn't pulling (slipping)?
Old Nov 12, 2009 | 12:23 AM
Re: Stall to much?
i run a stock converter in my s10 and z28 both have 420-454 lift and 214 duration @.050lift. they both pull hard off the line.
Old Nov 12, 2009 | 12:33 AM
xbox07's Avatar
Car: 86' Z28
Re: Stall to much?
Nah i don't think its slipping it just doesnt feel like it pulls as hard or responsive as before.
Old Nov 14, 2009 | 08:04 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: Stall to much?
well your 2.73 gears are terrible for quick launches.. upgrade to 3.27-3.45 gears and you will be much happier.... those are highway gears..... i have a 2200 stall and a B&M shift in my pro built 700r4 and it definitely doesnt feel sluggish at all...i had the transgo kit in my other tranny and it is a good one but i like the way my B&M shifts better than the transgo.. i dont know why people say the B&M is bad.... B&M is a very popular manufacture and sells parts for all out racing... i would think they wouldnt sell junk...
Old Nov 15, 2009 | 12:32 AM
xbox07's Avatar
Car: 86' Z28
Re: Stall to much?
I'm having other problems with it now it short shifts just normally driving then when i try to stomp it the shift points are way off and right after i do and try driving it normal again it tries to shift way to late. I know the cables not adjusted right but i'm starting to think theres still trash in the transmission.
Old Nov 15, 2009 | 01:46 AM
EvilCartman's Avatar
Car: '82 Z28
Re: Stall to much?
Adjust the tv cable NOW, then go drive it again to see if it's the same. Higher stall converter will not be snappy like a stock tight converter. Whole purpose is to let the engine get to a higher RPM quicker where there is more torque to blast you off. Below that 2000 rpm, it'll be slipping and feel lazy. I went from a stock converter to a 2500 stall and it felt really strange at first.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
