S60 street/strip spool?
Old 11-14-2009, 08:18 AM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, 3400 stall
Axle/Gears: S60 373
I have a very promising new body for the engine/trans of my old car. After thinking about it, I am considering a rear end swap while i am at it. I have heard nothing but good things about the S60, other than it sucks up a few more ponies than the 12 bolt or Ford 9".
I am looking for other members experiences with driving a spool S60 on the street. Is it too much on the axles? I am leaning towards the 35 spline axles, MAYBE the 40. Depends on what people say.
Old 11-14-2009, 08:25 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: S60 street/strip spool?
FWIW, a street driven spool will always be a compromise.. If you're serious about a true street/strip car, look at the TruTrac differential.. I've seen them continue to pull posi with one wheel on pavement and one off track in the dirt. Truly an amazing diff...
Old 11-14-2009, 09:51 AM
big gear head's Avatar
The 60 actually uses less power and is lighter than a 9 inch Ford. I would use a Detroit Locker over a spool any day. A spool is dangerous on the street. It stresses parts to much. I have seen broken wheels, studs and axles from using a spool on the street. 35 spline axles should be enough.
Old 11-14-2009, 11:21 AM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
35 spline are standard for S60's. go locker over the spool for street/strip use. I have one and it works great.
Old 11-14-2009, 05:36 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Are you running a 454 or 506? I dont think you will need 40 spline axels for any street driven small block. Try this site to get correct spline number, not only that the higher # of splines the more hp/torque u loose. http://www.moserengineering.com/Pages/axletech.html
cheesehomer
12-31-2015 08:48 AM
SRKLEGIN
Interior Parts Wanted
10-12-2015 07:28 AM
darwinprice
17
10-11-2015 11:51 PM
Mongoose462ci
09-16-2015 11:46 PM
Quick Reply: S60 street/strip spool?
