Best Diff & Trans for 550hp 383 Street/Strip car
Old Nov 15, 2009 | 09:18 PM
Quinny's Avatar
I am building a 550hp 383 which will find its way into a 3rd Gen. The car will be a street/strip car, and I was after recommendations of what auto transmission and diff to use. I am planning on running 4.11 or 4.44 gears, so I would prefer a trans with overdrive. Both will need to handle full launches with slicks at the strip.
Can a T700 be built to take that sort of punishment? If not, what other overdrive trans will take it? Are my only options for a diff a 9" or Dana 60?
Old Nov 15, 2009 | 09:21 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: Best Diff & Trans for 550hp 383 Street/Strip car
a built 700r4 would handle that power. Also a 12 bolt, 9" or a S60 will be fine.
Old Nov 16, 2009 | 06:35 PM
big gear head's Avatar
For less than 600 HP I would use a Moser 12 bolt. It's lighter, cheaper and easier to turn than a 9 inch, and more than strong enough for 600 + HP. I would use a 33 spline Eaton Posi with 33 spline axles and 9 inch Ford axle bearings to eliminate the c clips.
Old Nov 16, 2009 | 10:33 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have a built 700r4 with a 3200 stall
My best et is 11.0 @ 125.
I have 4.11 gears.
The trans is now starting to show symptoms of weakness and it is starting to slip when I shift from 2-3, although I have been racing this trans now for 3 seasons
Old Nov 26, 2009 | 06:20 PM
gpbtt's Avatar
Car: 1991 Camaro RS
Engine: 383 stroker
Axle/Gears: 3:73 Eaton limited slip
I have the original rear housing with an eaton posi, moser axels,4:10's rear cover and we are running a 500 (to the ground) 383 launch at 2500 WITH THE STOCK 5 speed! Runs 12.5 all day. Plus we road race the car. It was the second fastest at Taladaga Grand Prix lat time out!The stock trans has a bad bearing but it took 5 years to do it
Old Nov 26, 2009 | 09:02 PM
Quinny's Avatar
My original thoughts have been altered slightly from street registered strip car, to street car which occasionally gets used for the strip - seeing as the racing facilities around here are not exactly world class.
So drop the power to around 450, which is plenty for the street, and go to a manual gearbox - probably a TKO600, and 12-bolt diff, should be lots of fun!
Old Nov 27, 2009 | 04:25 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
No fun.. 550+ hp for the street, TKO600.
I'll probably go TKO when my TH350 blows up.
-- Joe
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
drathaar907
Aug 10, 2015 07:44 AM
Exxon Limited
Aug 9, 2015 08:13 PM
