9-bolt oil seal
Old Nov 17, 2009 | 05:44 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
9-bolt oil seal
Anyone have a source for 9-bolt right rear axle oil seal????
Old Nov 17, 2009 | 05:54 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 9-bolt oil seal
Double-check RockAuto (I'm enjoying happy hour, so who knows), but I think you'll find AC Delco right rear part #291309.
JamesC
Old Nov 18, 2009 | 07:41 AM
DJP87Z28's Avatar
Re: 9-bolt oil seal
[QUOTE=JamesC;4347352]Double-check RockAuto (I'm enjoying happy hour, so who knows), but I think you'll find AC Delco right rear part #291309.
JamesC[/QUOT
Thanks for the Info.....
Old Nov 18, 2009 | 08:21 AM
JamesC's Avatar
Re: 9-bolt oil seal
DJP,
I don't know if you're in a hurry for the piece or not, but note that it's a non-stock item at RockAuto. You might be able to pick it up faster at an auto parts store:
ACDELCO Part # 291309 {#00554631, 554631}
SEAL,RR WHL BRG w/**7.625 R/GR SAGINAW-AMERICAN**
* Non-stock item--shipping delayed up to 5 business days
JamesC
Old Nov 18, 2009 | 08:47 AM
DJP87Z28's Avatar
Re: 9-bolt oil seal
Originally Posted by JamesC
DJP,
SEAL,RR WHL BRG w/**7.625 R/GR SAGINAW-AMERICAN**------10-bolt?????
JamesC
Nothing critical at this point, just showing indications of a leak. I wanted to know the p/n so when I decide to replace it, I know the avaiiability. That seal number is for the BW 9-bolt?? Above lists for a 10-bolt.
Thanks again.
Old Nov 18, 2009 | 09:09 AM
JamesC's Avatar
Re: 9-bolt oil seal
Nothing critical at this point, just showing indications of a leak. I wanted to know the p/n so when I decide to replace it, I know the avaiiability. That seal number is for the BW 9-bolt?? Above lists for a 10-bolt. Thanks again.
Good grief--well, I did mention hap-hap-happy hour. How about this:
Below from post #4 of the following link:
https://www.thirdgen.org/forums/faq-...now-about.html
Auto Zone has the cheapest price on Timken Axle Bearings (8.99 each) Part # Set-9. You'll need to replace the seals also, available seperately timken part # 710179 for the passenger side (9.99) and 224255 (3.99) for the driver's side. They also sell Timken pinion seals part # 7457N (15.99)
JamesC
Old Nov 20, 2009 | 12:15 AM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Re: 9-bolt oil seal
i got mine from my favorite independent auto parts store they had to order it though, and I have no clue what happened to it when I moved : (
Old Nov 20, 2009 | 03:02 AM
Twin_Turbo's Avatar
Re: 9-bolt oil seal
Ratech apparently sells one, from summit it's a whopping 25 bucks..probably cheaper elsewhere.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tgp1990
Sep 4, 2015 06:24 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
