Speedometer correction HELP
Old Nov 20, 2009 | 03:00 PM
DC1992Z28's Avatar
Car: 1992 Z28
Axle/Gears: 10 BOLT 3.73 POSI
From the factory my camaro had a 2.73 gear since it has been changed to a 3.73 , and my speedo reads way off, My understanding is that runs off a speed sensor on the transmission, how can I get the correct speed to register.
Old Nov 20, 2009 | 03:26 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: Speedometer correction HELP
You need to change one or both of the speedo gears in the transmission tail housing, not sure which. The ratio is determined by the color of the gears and there are several different colors available. Also, if your car has the electronic speed sensor you may need to change the permanent magnet generator, because I do not think that gear alone is replaceable. Also the tail shaft has 2 mounting holes for the drive gear you may or may not need to move the gear to the other hole, if things don't fit back in right.
Do a search and you should be able to find the right combination.
Old Nov 20, 2009 | 03:30 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hey, DC,
Welcome to TGO. As you'll discover, using the search function on site is always a good idea. For the time being, check the stickies at the top of the page.
JamesC
Old Nov 23, 2009 | 02:07 PM
DC1992Z28's Avatar
Car: 1992 Z28
Ok thanks for the info , yes im new to the site and it is very heplfull to have all of this knowledge at my disposal.
Thank Again.
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
TrevinE
Sep 14, 2015 03:20 PM
andy74
Sep 3, 2015 08:41 AM
