4th Gen Rear end
Old Nov 21, 2009 | 11:32 PM
tanda10506's Avatar
4th Gen Rear end
I've read that the 4th Gen rear end's bolt right in to the third gen cars. But if your 3rd gen is drum in the rear do you have to change anything for the new disc brakes on the 4th Gen rear end?
Old Nov 21, 2009 | 11:44 PM
Stephen's Avatar
Car: 87 GTA
Re: 4th Gen Rear end
HAVE TO? No. Some will change out the proprtioning valve too, some won't. It's a LONG standing "arguement" here on TGO to do it or not, that will never be solved!
Old Nov 22, 2009 | 12:03 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
yea someone needs to do some kind of controlled test w/ a drum valve and a disk valve, but that still wouldn't end it
Old Nov 22, 2009 | 12:50 AM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I swapped in LS1 rear disks about a year ago and firured what the heck, might as well try it with the disk/drum prop. I had a disk/disk prop sitting there anyway. I made a trip around the block and immediately pulled the disk/drum off and put the disk/disk prop on. The car didn't stop for crap, even with the 13" wilwood brakes I designed and built for it on the front. Was a major difference with the 4 wheel disk prop valve.
Old Nov 22, 2009 | 06:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Change the proportioning valve for the best braking performance. Proportioning valves were designed to optimize specific systems: disc or drum. While the car will stop without the appropriate valve, the system won't be at its best, and if the system isn't going to be at its best, why swap in bigger/better brakes at all.
To the OP, check the following FAQ for more info on what you'll require for the swap:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
hectre13
Dec 11, 2023 08:14 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
